Sticky Notes Transparency Reset Issue After Sleep Mode Activation
samsam
Post by samsam »
I adjusted the transparency of my Sticky Notes to 40%. However, after activating the 'Sleep for 1 hour' option, upon waking up, I noticed that the transparency setting had reverted back to 0% instead of retaining the 40% I had initially set.
I'm using the latest version of EPIM Pro 11.8.2.
Has thanked: 1424 times
Been thanked: 990 times
Re: Sticky Notes Transparency Reset Issue After Sleep Mode Activation
We're unable to reproduce this problem, unfortunately. Was it a one-time occurrence on your side, or are you able to replicate such behavior? Thanks.
samsam
Post by samsam »
I've encountered the same issue on two separate PCs. Please refer to the attached video demonstration. I conducted a test where I adjusted the transparency level to 80%, but upon waking up from sleep mode, the level reverted back to 0%.
The video is sped up.
Sticky Notes Issue.mp4
(756.91 KiB) Downloaded 21 times
Thank you for the video, we were able to reproduce the problem. Please expect a fix in the next EPIM update.
