Frustrated and lost data!
bobmac1547
Been thanked: 10 times
Post by bobmac1547 »
I was keeping a record open for a while as I progressively added notes from my dictations. (Once I add the note, I delete the dictation which is then unrecoverable.) I must have had several hundred words written in the contact record when the program crashed. So I lost all my work. And since the dictations and thoughts were unrecoverable, I truly lost it all.
Had there been a SAVE button without the closing of the window, this would not have happened.
I have asked before, yet nothing has been done: Again, PLEASE add a button to the contact window to SAVE the record without closing it. Programmatically, it's insanely simple to do. You already have SAVE AND NEW. It's not a huge leap to add a simple SAVE button and leave the window open.
This has happened to me several times and it's starting to become more than annoying. It's starting to become a show-stopper for me. I don't know how many others are having the same experience, but I know that I, for one, can't tolerate it much longer. If I don't see the save button soon, I'll be leaving EPIM for another program that does not have this issue. (There are many!)
Max! Are you listening?????
Has thanked: 1424 times
Been thanked: 990 times
Re: Frustrated and lost data!
Thank you for the suggestion, although we would much prefer to address the cause (which is a crash) of the issue, rather than dealing with the consequences that stem from it. Please mention your EPIM version number and the error message you received. Thank you!
bobmac1547
EPIM version 11.8.3
There was no error message. The application just closed and I lost everything.
Even if you fix whatever bugs occurred, there really should be a "save & Keep Open" button just as you have a "Save & New" button.
Why is there such reluctance to have it? Please be honest about it.
It seems very unlikely that the application simply closes without showing any messages first. How frequently does the problem occur on your end? Have you noticed any patterns that could potentially lead to such behavior?
bobmac1547
It was only once that it closed without an error message. The rest of the times there's always a message and I send that report to you.
