EPIM 11.8.3 can not be downloaded
kdgdr
Has thanked: 9 times
Been thanked: 18 times
Post by kdgdr »
Seems like there 's an issue with the download currently.
See attached screenshot
2024-03-11_161622.pdf
(60.04 KiB) Downloaded 24 times
Kind regards
My setup:
WEPIM ProPort. 11.6.5 on Windows 10 <2-way sync over Wifi> AEPIM 6.0.13 on Samsung A52s 5G (Android 12 - One UI 4.1)
PeCe
Has thanked: 101 times
Been thanked: 330 times
Re: EPIM 11.8.3 can not be downloaded
Post by PeCe »
Maybe it was a temporary glitch that prevented your from downloading?!
For me both download links on the EssentialPIM.com website work without any problems.
I could download the files, checked them and they still are 11.8.3 from 27 february.
If the problem persists, may check the firewall or AntiVirus if it prevents this download.
kdgdr
Post by kdgdr »
Hi Peter,
In Chrome still same issue as in the screenshot in my previous post.
In Edge I get this remark:
2024-03-12_120903.pdf
(494.73 KiB) Downloaded 19 times
After clicking the download from Edge, I get this:
2024-03-12_121154.pdf
(9.15 KiB) Downloaded 17 times
I'm downloading from Belgium and never had these issues before.
Has thanked: 1424 times
Been thanked: 990 times
Unfortunately, we are unable to confirm the reported issue as everything is working as expected on our end.
