Why you DON'T like EPIM?
todd
Re: Why you DON'T like EPIM?
Post by todd »
I am pretty much in agreement with the general thread here. Everytime a new release comes out I hold my breath hoping it didn't break anything essential to me, but the previous release broke my calendar/reminder screen which I rely on every single day. I posted a message on the support forum, got one or two replies, and then nothing, and the complaint was still unresolved. So basically someone just threw up their hands and there has been no follow up since. This is in addition to an ongoing complaint from a number of releases ago on the lack of ability to sync when I try to sync to my Iphone. This too was abruptly dropped.
The calendar though I really need to work, so when it was obvious I would get no help I solved the problem myself by going back to a third party calendar program that always worked well and still does and now I get my reminders in the morning again. So goodbye epim calendar module. That leaves me pretty much only using the Note module.
There is a minor but annoying bug in notes that I would like to see fixed and I have left a suggestion. My plan is to keep checking the new releases using my virtual machine to prevent my current release from having new bugs introduced, and when / if I see the fix I intend to update and freeze my version at that point. I have already passed up the latest release.
We would appreciate it if you could provide us with the topics you believe we have not addressed adequately. We always strive to identify the root cause of issues and resolve them as quickly as possible. However, sometimes there may not be anything to fix. Please let us know so we can take appropriate action.
victor09
Post by victor09 »
In the notes, add formatting for well-known file formats and programming languages such as SQL, VB.Net , C#, xml, etc. So, for example, it was done in Notepad++. This will be very convenient for storing request fragments and code.
Thank you very much for the suggestion. We truly appreciate it!
alex4EPIM
Has thanked: 15 times
Post by alex4EPIM »
I'd like to make some notes locked - read only
I managed to do it in a pc through a forum post I have started at
viewtopic.php?t=38237
Laurent C.
Has thanked: 5 times
Been thanked: 14 times
Post by Laurent C. »
Yes, should be :!:
EPIM Pro + EPIMA Pro (Android) / W10 Pro 64 bits FR + Office 2019 Pro Plus / Pixel 7 Pro
Triple S
Been thanked: 7 times
Post by Triple S »
Updates keep making EPIM worse.
For some time now using EPIM has for the lack of better words sucked. But I remembered loving working in EPIM notes, so I decided to check the update log and find the version that added note zoom. That's when it all started going down hill. Ever since note zooming was added the window lagged something fierce when resizing, and every update after that just seemed to make notes worse. Search stopped finding the notes I was looking for without having to put everything in quotes, than in the last couple of version the interface for notes have become unbearable.
After spending a day back porting all my notes to 9.10, which was a royal pain given that there is no good way to downgrade. I basically looked through my backups found the last 9.10 database I had (Dec 12th 2021) and then spend a bunch of time back porting new things since then.
Overall I am super happy with the results 9.10 is fast, friendly, efficient. Everything I remember loving about EPIM. It feels like a major upgrade after using 10 and 11 for the past couple of years.
So I guess my lifetime license ends at version 9.10.
Trinitylab
Has thanked: 17 times
Been thanked: 43 times
Post by Trinitylab »
My best was ca 5.x.
Since then, well, nothing but agree with Triple S.
The first not user friendly decision was to introduce this crazy window, to edit all fields in contact record, instead of using All tab. Probably 7.x.
Anyway, sucks completely, and I don't use mail module, that would kill us probably.
Win 10 Pro 64x
Laurent C.
Anyway always a good alternative :wink: to sync without a cloud the notes between mobile and PC, and even Outlook — Rgds
Konserv
Has thanked: 18 times
Post by Konserv »
The GUI
White text on white background with flat dull white icons that make you snow blind.
The white text on white background with big white padding around items (atleast we got rid of that padding) is just bad modern GUI
that makes it hard to focus and read, and that all black GUI does not make it better just another version of bad.
We used to have such nice computer GUIs in with black text on greyish background with colorfull nice icons. Easy to use, easy to see, easy to find what you want to do and above all easy and relaxing on the eyes.
Conflict handling
When a conflict happens the conflict resolver shows only on the desktop and not on the handheld.
Thing is that when syncing with the phone im not going to be near my computer, the sync is started from phone only so I will be at my phone and not the at the computer.
A setting to create duplicates of all conflicts would resolve this if the conflict handeling can't be displayed on the Android.
Only one calendar sync
Only one calendar can be synced to AEPIM, your shared calendars, all your nice icals, no sync for you!
No USB-sync
No, that USB-sync we have is just wierd.
Spying AEPIM
AEPIM adroid is contacting some 1net100-adress even if I turn off "share non anonymous data with NSA".
No email in AEPIM
No Email on AEPIM.
Costumization
No way to change icons and customize icons the gui.
Nextcloud sync
Nextcloud takes forvever to sync. DAVx⁵ on mobile is almost instant!
Thats about it.
Dierk
Has thanked: 35 times
Been thanked: 9 times
Post by Dierk »
Conflict handling
A setting to create duplicates of all conflicts would resolve this if the conflict handling can't be displayed on the Android.
Would give this a hearty "Second!" Obviously (presume it should be Obvious...) would like to then see a Sync Report showing which entries were Duplicated.
Laurent C.
1 point : some perimeter constraints — true — but EPIM if one of the offers that have resisted for years = I have seen so many products disappearing too quickly — EPIM is solid for the long term at least — hopes that your requirements will be fulfilled... Regards.
clarkbar
Post by clarkbar »
Screen refreshing and notifications are full of bugs. After x number of emails are read and deleted the number of recent ones still show up in "all mail" and "important" as if they haven't been read. Calendar appointment changes, notes, tasks and their completions and priority flags don't show updated until the program is brought down and back up. The notification of new unread mail on the taskbar will jump to an email deleted weeks ago. This has happened on both my old and new Win 11 PC.
Are you currently using the latest version of EPIM, version 11.8.x? Since there have been no similar reports from other users about the issues you mentioned, it might be beneficial to ensure that you are on the most recent version to potentially address any issues you are facing. If you are not on the latest version, updating to the newest release could help resolve the problems you are encountering.
Trinitylab
admin wrote: Mon May 13, 2024 10:05 am Are you currently using the latest version of EPIM, version 11.8.x? Since there have been no similar reports from other users about the issues you mentioned, it might be beneficial to ensure that you are on the most recent version to potentially address any issues you are facing. If you are not on the latest version, updating to the newest release could help resolve the problems you are encountering.
Dear Admin, there have been numerous reports on the problems with notifications, years ago.
Like the simplest and most basic one:
the triggered reminder is not marked and/or on top of the list in the reminders window.
Win 10 Pro 64x
