Collapse all that are expanded
Expand all that are collapsed
If a few are expanded it has to expand the remainder before it can collapse all.
Expand/Collapse All
- Has thanked: 9 times
- Been thanked: 51 times
- Has thanked: 1445 times
- Been thanked: 1006 times
Re: Expand/Collapse All
Please read the first post here: viewtopic.php?p=31546#p31546.
The problem is minor, but I think it speaks for it's self, sorry I mentioned it.
I think it's in all versions.
Win11 Pro Ver. 23H2 (OS Build 22631.3593) 64-bit, 32GB Ram, 500gb M.2 SSD, 4Km, EPIMPro Life 12.b2
I'm not sure we understand the problem, unfortunately. Could you please specify the EPIM module that was involved in the experiment? What do you expect the behavior to be? Thank you!
1. In the note tree if All are expanded and you collapse a few notes, later you want to collapse the remainder that's not collapsed. Click the Icon in the toolbar and All is collapsed.
2. In the note tree if All are collapsed and you expand a few notes , later you want to expand the remainder that's not expanded . Click the Icon an All is collapsed.
You have to click the Icon again to expand All.
#1 is working correctly.
#2 is working incorrectly.
We're unable to reproduce point number 2. Clicking on the "Expand/Collapse All" button expands all notes. If this feature behaves differently for you, could you please record a short video demonstrating the issue? Perhaps there is something we are overlooking in our attempts.
