Application error
kamarad
Re: Application error
Post by kamarad »
Hello!
When restarting the programs, folders in the contacts module become double or triple double, according to the attached video?
It doesn't help to delete folders, and then the programs have to be closed with task manager, they come up again when restarting the programs!
Video_241210094447.mp4
(4.71 MiB) Downloaded 54 times
kamarad
Post by kamarad »
When installing the programs under the start button on the computer is there a shortcut to both EssentialPIM and EssentialPIM Pro, according to the attached video?
Video_241210100259.mp4
(1.47 MiB) Downloaded 54 times
You're unable to delete the contact groups due to an error, which will be addressed in the upcoming release.
This issue is likely a leftover from one of the legacy versions that may still be installed on your PC.
kamarad
Post by kamarad »
Hello!
How can you see in the database what the size goes to?
What takes up the most space, whether it's emails, notes or something else?
kamarad
Post by kamarad »
When I use the programs, a dialog box suddenly appears, according to the attached pictures, saying that there is an error in the programs that then shuts itself down?
Also, it is very slow, it happens that you have to wait about 10 seconds for it to respond and often everything turns gray, it just goes silent and blocks the entire computer.
Definitely that it does not work, not with me in any case, unfortunately.
Click on File->Database Management.
When I use the programs, a dialog box suddenly appears...
How can we reproduce this issue on our end?
kamarad
Post by kamarad »
New dialog boxes appear suddenly and cannot be predicted, but other errors when they occur can be played back.
Right now, I have played back two videos, according to the attached files, which show that the programs simply refuse to work.
Video_241217165307.mp4
(7.52 MiB) Downloaded 35 times
Video_241217165107.mp4
(1.23 MiB) Downloaded 31 times
kamarad
Post by kamarad »
I restarted the programs and immediately it was blocked according to the attached video.
Video_241217170413.mp4
(2.8 MiB) Downloaded 35 times
Have you already tried the latest version 12.1.2? Will you experience the same issues with this new version? If so, please test it with a new database and let us know if the problems persist.
kamarad
Post by kamarad »
I have already tried with 4.5 new databases and after a while the same problem occurs. I have also protected the database with code but that does not help either.
kamarad
Post by kamarad »
Now, when restarting, the programs immediately stop working, according to the attached video.
https://www.icloud.com/iclouddrive/0bdN ... 1217233706
kamarad
Post by kamarad »
I started the programs and the following error message immediately appeared:
Exception log with detailed tech info. Generated on 2024-12-19 10:14.
Application title: emde241210-1.epim - EssentialPIM Pro
Application: EssentialPIM Pro 12.1.2 2024-12-17
Exception class: EThread
Exception message: Thread Error: Referensen (handle) är felaktig (6).
Exception address: 004D1E38
Main thread ID = 2480
Exception thread ID = 2480
Object Logs:
10:14:45.503 AppRestore OK
10:14:45.480 SetViewMode OK
10:14:44.690 SetViewMode 5
10:14:44.685 AppRestore
10:14:36.699 REMINDER
10:14:35.495 REMINDER
09:59:32.995 REMINDER
09:59:32.949 REMINDER
15:21:50.200 AppMinimize OK
15:21:49.957 DBSave OK
15:21:49.627 DBSave
15:21:49.627 AppMinimize
15:21:12.786 SetViewMode OK
15:21:12.373 SetViewMode 5
14:40:24.328 TASK
14:38:16.820 TASK
14:35:56.779 TASK
14:35:11.144 TASK
14:32:32.391 TASK
14:32:32.389 REMINDER
10:14:51.021 MainForm FormPan FormPan2 MailForm FoldersVT
10:14:47.436 MainForm FormPan FormPan2 MailForm MessagesPan MsgListPnl MessagesVT
10:14:45.801 MainForm
10:14:36.896 MailThreadsForm ThreadsVT
10:14:32.410 ReminderForm RemindersTC
09:59:35.092 MailThreadsForm ThreadsVT
15:21:35.249 MainForm FormPan FormPan2 MailForm FoldersVT
15:21:16.878 MainForm FormPan FormPan2 MailForm MessagesPan MsgListPnl MessagesVT
15:21:15.433 MainForm FormPan FormPan2 MailForm FoldersVT
15:21:13.370 MainForm
SQL Log:
10:14:52.345 Prep select Headers from MessageView where idMessage=:P0
10:14:52.346 Prep select Body from MessageView where idMessage=:P0
10:14:52.359 Prep select FileName from AttachmentNameView where idParent=:P0
10:14:52.363 Prep select BodyText from MessageView where idMessage=:P0
10:14:52.365 Prep select Headers from MessageView where idMessage=:P0
10:14:52.366 Prep select Body from MessageView where idMessage=:P0
10:14:52.374 Prep select FileName from AttachmentNameView where idParent=:P0
10:14:52.375 Prep select BodyText from MessageView where idMessage=:P0
10:14:52.400 Prep select idToDo,idParent,idList,Created,LastChanged,Title,Text,StartTime,EndTime,Location,Priority,Completion,Completed,Category,Expanded,ToDoIndex,ShowInSch,idEditor,ReadAccess,WriteAccess,Text2,Tags,FieldsData,FieldsData2,Floating,FollowUpID,idReminder,ShowTime,SoundType,SoundFile,MessageType,MessageText,RunProgram from ToDoFullView where Status=0 and FollowUpID=:P0
10:14:52.409 Prep select detected,curtrans,hidden,translations from MessagesTrans where idMessage=:P0
10:14:52.434 Prep select idFolder from MessageView where idMessage=:P0
10:14:52.434 Open select detected,curtrans,hidden,translations from MessagesTrans where idMessage=:P0
10:14:52.434 Prep select idAccount from MailFolderView where idFolder=:P0
10:14:52.435 Prep select TemplatesFolder from MailAccountView where idAccount=:P0
10:14:52.437 Prep select idAttachment,idParent,LastChanged,FileName,Size from AttachmentFullView where idParent=:P0
10:14:52.438 Prep select idField,Visible,Width,FieldIndex,DefVisible,DefWidth,idParent from FieldFullView where idTable=:P0 and idParent=0 order by FieldIndex,DefFieldIndex
10:14:52.439 Prep select SortFields,SelectedItem from ViewParamView where idView=:P0 and idParent=:P1
10:14:52.442 Prep select idAttachment,idParent,LastChanged,FileName,Size from AttachmentFullView where idParent=:P0
10:14:52.443 Prep select idField,Visible,Width,FieldIndex,DefVisible,DefWidth,idParent from FieldFullView where idTable=:P0 and idParent=0 order by FieldIndex,DefFieldIndex
10:14:52.444 Prep select SortFields,SelectedItem from ViewParamView where idView=:P0 and idParent=:P1
Memory: 12108; free 6417
Updates: 1
Last update: 2024-12-18"
kamarad
Post by kamarad »
and then this message came up and the program was shut down!
kamarad
Post by kamarad »
I have restarted the program but the error comes up again, as in the attached image.
