Make Appointment appear at today day till delete?!
hi admin, community,
need to have the appointment showing at actual day till delete and/or change!
any way to do it?
or need new extra feature?
millions thanx!
any way to do it?
millions thanx!
Helps Make EPIM Great/No1!
- Been thanked: 1135 times
Re: Make Appointment appear at today day till delete?!
This feature is available for tasks. Ensure the Float checkbox is enabled when creating or editing a task (this will only work if a due date/time is set).
please make it also in appointments!admin wrote: Mon Feb 17, 2025 2:36 pm This feature is available for tasks. Ensure the Float checkbox is enabled when creating or editing a task (this will only work if a due date/time is set).
i need it there to as use tasks and appointments fluently or better said:
if i want to see it in the middle in todaysview i set appointment, but some less important overhead had to stay at today, so move automatically a day forward!
other user has the case with tasks, but as i need to see some in the appointment section, so need the floating there!
million thanx!!!
EDIT
can you move it to 'Suggestions' section or not possible? thanx!
Why not create a floating task and set it to appear in the Calendar?
