HELP NEEDED! How to work with task as appointment?!
hi admin, all,
i need explanation on How to work with task as appointments...
is there maybe a short video explanation with example?
do you use youtube to explain and marketing?
hope it helps both ways and us and you
many thanx!
many thanx!
Helps Make EPIM Great/No1!
- Has thanked: 13 times
- Been thanked: 44 times
Re: HELP NEEDED! How to work with task as appointment?!
Could you first please explain by example what you want to have and why?
You can misuse modules for different purposes. I use tasks not at all, and appointments for my are just a NOTE to a single date.
EPIM is flexible!
EPIM is flexible!
not flexible / customizable enough, like i mentioned in my last threads.a8907433 wrote: Sun Feb 23, 2025 12:51 pm You can misuse modules for different purposes. I use tasks not at all, and appointments for my are just a NOTE to a single date.
EPIM is flexible!![]()
no idea why not put floating in appointments too, as the user should decide how he uses it, like you do!
i don't want to do olympic tricks, if i have a pending appointment depending on sth., i want just to do it so, and don't go over tasks. i try to use it my way and don't be pushed in other way. it would make sense to show this appointments, at least as user choosed/activated, at the top of epimtoday appointments!
it's still quite much to do.
i hope we get the smaller ones quick.
- Has thanked: 18 times
- Been thanked: 14 times
A task is something that needs to occur with no set time. Sure you can set reminders so you can work on a task. An appointment must be done on a certain date and time.
thanxDavidN wrote: Mon Feb 24, 2025 11:44 am A task is something that needs to occur with no set time. Sure you can set reminders so you can work on a task. An appointment must be done on a certain date and time.
my conclusion is that i need floating appointments and a area with such and/or pined appointments and maybe tasks.
i have dependencies appointment to keep in view on top of the epimtoday appointments like you have allday tasks in one day calendar view.
