**** is not a valid integer value
poet-man
Has thanked: 13 times
Been thanked: 44 times
Post by poet-man »
Using build 1032 and letting EPIM have a look for availability of a new version, produces the above message.
Has thanked: 1616 times
Been thanked: 1134 times
Re: **** is not a valid integer value
Which update channel are you on? How do you check for new versions? Also, could you please attach a screenshot of the error message?
poet-man
Post by poet-man »
I check by help menu -> check for updates
The error message is exactly as written in subject line (notebook not available for screenshot right now)
Moreover I sometimes geht the message you see in screenshot attached.
poet-man
Post by poet-man »
EDIT:
Download/install from web-site led to build 1033. There, the above errors donot seem to come up anymore.
DG
Beta Team
Has thanked: 29 times
Been thanked: 41 times
Post by DG »
Confirmed on both accounts. I had the same error with build 1032 but checking for updates with build 1033 works.
lorymax
Been thanked: 9 times
Post by lorymax »
I have build 1133, from today I see the same error
poet-man
Post by poet-man »
Since I use 1033, the prob didnot come up anymore. So we have 1133 now?
lorymax
Post by lorymax »
poet-man wrote: Fri Feb 28, 2025 7:58 pm Since I use 1033, the prob didnot come up anymore. So we have 1133 now?
sorry I wrote wrong. I have 1033 and from today there is the problem.
poet-man
Post by poet-man »
Ah I see. When did you download build 1033? I downloaded it from epim homepage!
lorymax
Post by lorymax »
if I remember correctly I downloaded it with the epim update function
lorymax
Post by lorymax »
anyway i confirm - i use EPIM Pro 12.1.3 build 1033 and the problem occurs. It started only yesterday even though i updated to this version as soon as it was available.
lorymax
Post by lorymax »
from another older installation of EPIM I see that 12.1.4 build 1034 is available and it seems not to have the problem anymore.
Now I just have to wait for it to be available for download on the site, since it is not possible to use the update function.
We'll look into this, thank you for reporting the issue!
lorymax
Post by lorymax »
I solved it with a downgrade by installing the previous version 12.0 - then the update worked and downloaded 12.1.4. At the moment the problem has not occurred again :D
pimpam
Post by pimpam »
I have the error with version 12.1.3 (Build 1033, Lifetime) when I go to 'check for updates' (message: '... is not a valid integer value'). To update to 12.1.4, can I simply download the trial version from the website and install it over version 12.1.3?
