**** is not a valid integer value
- Has thanked: 13 times
- Been thanked: 44 times
Using build 1032 and letting EPIM have a look for availability of a new version, produces the above message.
- Been thanked: 1134 times
Re: **** is not a valid integer value
Which update channel are you on? How do you check for new versions? Also, could you please attach a screenshot of the error message?
I check by help menu -> check for updates
The error message is exactly as written in subject line (notebook not available for screenshot right now)
Moreover I sometimes geht the message you see in screenshot attached.
EDIT:
Download/install from web-site led to build 1033. There, the above errors donot seem to come up anymore.
Since I use 1033, the prob didnot come up anymore. So we have 1133 now?
sorry I wrote wrong. I have 1033 and from today there is the problem.poet-man wrote: Fri Feb 28, 2025 7:58 pm Since I use 1033, the prob didnot come up anymore. So we have 1133 now?
Ah I see. When did you download build 1033? I downloaded it from epim homepage!
anyway i confirm - i use EPIM Pro 12.1.3 build 1033 and the problem occurs. It started only yesterday even though i updated to this version as soon as it was available.
from another older installation of EPIM I see that 12.1.4 build 1034 is available and it seems not to have the problem anymore.
Now I just have to wait for it to be available for download on the site, since it is not possible to use the update function.
We'll look into this, thank you for reporting the issue!
I solved it with a downgrade by installing the previous version 12.0 - then the update worked and downloaded 12.1.4. At the moment the problem has not occurred again
I have the error with version 12.1.3 (Build 1033, Lifetime) when I go to 'check for updates' (message: '... is not a valid integer value'). To update to 12.1.4, can I simply download the trial version from the website and install it over version 12.1.3?
