Dont See Marking of Today in WeekView!
AJ
Has thanked: 48 times
Been thanked: 7 times
Post by AJ »
i definetively need better marking of today in weekview, as to small shown area on standard laptop to quick or sometimes any way to localize today!
the line over today in weekview is much to low overview!
pls mark the all day!
thx
Helps Make EPIM Great/No1!
AJ
Post by AJ »
hi admin,
on standard laptop to unvisable, maybe ok on monitor.
i would even prefer just to have the frame around today in weekview in background color, and only the top line blue, as i have/it is.
it would be then smooth but good orientation!
no i cant see anything, if shown area doesnt fit, which is even on standard laptop often.
earlier it was there and great! if its annoying someone then make it at least activable by user!
its optimal for finding today and eye fixing todays appt, otherweise its too nerving to find / bad orientation!
its one of reasons i have to use old vers and actual only for finding of inconvenience!
thx for understanding!
ps. i forgot week in subject! hope you get now what i mean!
