12.2 / size column width to optimum
poet-man
Has thanked: 13 times
Been thanked: 44 times
Post by poet-man »
Hi there,
today downloaded/installed 12.2 version.
What I realise, is, that in horizontal views (table views) width of columns is very small. To view content I have to move borders to normal width.
Is there a possibility to get optimum width automatically (as to content, which is there), without needing to change each column?
Thx
Has thanked: 1616 times
Been thanked: 1133 times
Re: 12.2 / size column width to optimum
Double-clicking on the vertical divider between the two columns should adjust the column on the left to its optimal width, based on the length of its longest content.
M&M
Has thanked: 10 times
Been thanked: 12 times
Post by M&M »
where can I deactivate the column optimization?
I have not found a corresponding setting either in the options or in the View menu.
Regards M&M
You cannot do that. Is there a situation where you find the current behavior disruptive?
poet-man
Post by poet-man »
@admin
So this means I will have to do that double-clicking for each column, which will make me busy for quite a long time! I would suggest to have a function in options to do that for all columns automatically???
Let's wait to see if we receive more similar requests from other users.
poet-man
Post by poet-man »
Let's hope there are, because it really is some kind of frustration.
One more question to that:
How do I save column widths, to have it there again after restart?
Thx
Column sizes are saved automatically.
poet-man
Post by poet-man »
On my side, they are not. After restart it's the same again.
Well to be honest ... I just had another try ... doing doubleClicks on some deviders, I have correct widths there. But after restart only some widths are correct and others are not again.
So horizontal views are not usable for me.
M&M
Post by M&M »
Hello admin,
I mainly use the “Customized View” for content-oriented display and due to the dynamic column width, content that is important to me is sometimes no longer fully displayed.
I prefer to scroll the table than to adjust it each time according to my preferences.
Regards M&M
poet-man, could you please record a short video demonstrating the issue?
M&M, understood, thank you very much for the explanation. We'll look into introducing an option that allows users to choose between the new and old behavior types.
M&M
Post by M&M »
Hi admin,
I'm sticking with version 12.1.4, as the constant reconfiguration of the columns to suit my needs is very annoying.
Regards M&M
M&M
Post by M&M »
admin wrote: Tue Apr 15, 2025 4:20 pm Column sizes are saved automatically.
Hello admin,
unfortunately the column width is not saved for me, I have to set the column width every time I start EPIM - quite annoying.
Does saving the column width have to be set in the options - I haven't found an option though.
Regards M&M
DavidN
Has thanked: 18 times
Been thanked: 14 times
Post by DavidN »
Experiencing the same issues.
aurio
Has thanked: 8 times
Post by aurio »
admin wrote: Tue Apr 15, 2025 12:45 pm You cannot do that. Is there a situation where you find the current behavior disruptive?
I don't have 12.2 in use yet, so I'm not sure if I understand it correctly. But it would really bother me if columns changed automatically and/or independently due to the content. I am happy to have a uniform setting across many task fields, which is why I think the copy function of the view is great. So the look is always the same.
If I understood correctly that the columns keep changing here, that would be an absolute setback for me.
EPIM Pro 11.8.4 Business Edition - 3 Users - Network
Language: German/English
