Move overdue tasks to top
wrbird
Post by wrbird »
Currently my overdue tasks show at the bottom of my essentialPIM Today list. How can I move them to the top?
Been thanked: 363 times
Re: Move overdue tasks to top
if you mean To Do's- they are sorted in the same way as in the To Do module. So you can go to To Do module, sort your items accordingly and come back to EPIM Today.
glenn59
Has thanked: 37 times
Been thanked: 15 times
Post by glenn59 »
Old thread I know, but I am having the same problem.
On Android widget, there are two groups, "NO due date" and "Overdue".No matter how I sort, the items in each group sort correctly. But, I would like to move the group "Overdue" to appear at the top of the sort list, above "NO due date" group, or any of the scheduled due dates.
Is this possible?
Thanks in advance,
Glenn
EPIM Android Pro v6.0.17 -Samsung A52-5G - Android OS v14
EPIM Portable Pro V6.0 RC2
EPIM Desktop Pro V8.64 - Windows 10
Has thanked: 1739 times
Been thanked: 1248 times
In EPIM Today, tap Settings and adjust the "Late tasks position" option to customize how overdue tasks are displayed.
glenn59
Post by glenn59 »
I can't find "EPIM Today" in the android app. In "Calendar" section, I don't see a menu option for "Late tasks position".
You're posting in the "EPIM for iPhone/iPod Touch/iPad" forum, so I assumed you were referring to the iOS version of EssentialPIM. If any case, I'm not sure where in the Calendar module of Android EPIM you would see an "Overdue" section. Could you please clarify?
glenn59
Post by glenn59 »
Admin, sorry for the delay in responding. The "Overdue" tasks returned to the top after I found a setting under Tasks settings and unchecked it. The setting reads "Show tasks without end dates at top". Unchecked that apparently allows "Overdue" to return to the top of the list.
My dilemma is solved.
glenn59
Post by glenn59 »
Also, my apologies for posting an Android issue in the wrong thread. I found the thread via search and wasn't aware it was an IOS thread.
