Label Print Problem
streethawk
Label Print Problem
Post by streethawk »
Hello...
...i have a little problem with Labelprintfunction. I choice a Label and
i insert my text. But the Position from my text, is not the same Position on
my printed label. I move the text in the Insertdialog but the Position from
my printed text is every time on the same place.
Can you help me?
I have the portable PIM 3.21 on Win XP.
best regards....streethawk
Re: Label Print Problem
Please make screenshots. Demonstrate what you enter and what you receive in the end (print to PDF or screenshot the Preview window)
streethawk
Hi...here the screenshots and i hope you know what i mean.
Placement_sample
Placement_sample
Thanks, was able to reproduce. Will fix.
streethawk
I have updated the 3.22 version (portable) and my Labelproblem is not away. The problem is now invers. I can´t see now the text moving in the edit-dialog. But now in the preview. The problem is the same. Just different than before. I have no WYSIWYG!
best regards Streethawk
Yes, confirm, sorry for the inconvenience. Will have to fix that once again in the next build.
just to check- I guess now label printing works fine?
