the function of checking for new version does not work
Max,
the EPIM's function of checking for new version does not work.
My EPIM is now Pro 3.5,if I do not forget ,I think this function did not work since the version of 3.5X.
My system is Vista basic and updated on time.
I use pop3 to send and receive email.
When I use the funtion,no response other than just "read timed out".
Can you help me solve the problem.
Best Regards
Pulse Ma
Best Regards
Pulse Ma
- petrsimanek
- Has thanked: 19 times
- Been thanked: 11 times
Re: the function of checking for new version does not work
I cannot confirm, it works OK for me.
Maybe it's something wrong with your internet connection (firewall setting or something like that)
Petr
Petr
Petr Simanek
EPIM user since April 2006, Beta Team member, always uses the latest stable and beta/RC version under Windows 10 Pro
Yes, most probably it is Firewall and/or very slow connection.
Mine doesn't work either. 3.51 Epim ProPortable. Windows XP servicepak 3.
Please switch off firewall for a second to test.
Switched off firewall. Makes no difference. Checking for updates in Epim 3.51 Pro Portable, I still get the message that there ar no updates availble.
This is not the error we are talking about here:) The original poster said about "Read timeout error".Wilco wrote:Switched off firewall. Makes no difference. Checking for updates in Epim 3.51 Pro Portable, I still get the message that there ar no updates availble.
Your one is working perfect. It will say about update 3.52 later today.
