Wrong year date and age in Birthday reminder
VictorParkerPIM
Has thanked: 9 times
Been thanked: 70 times
Post by VictorParkerPIM »
Vista Home Prem. ver. 3.54 Desktop Pro
Wrong date and age.
Date is correct in Contacts.
Program seems to be using (Repete Task, Expires Date )
1. Add Name in Contacts, enter birthday. (save)
2. Go to Month Schedule and edit birthday just entered and open the series.
3. Notice Task expires 9 years after birthday.
Some how the expires date causes the person to be 9 years older than should be.
I hope this helps solve the problem.
Vic
veganchris
Re: Wrong year date and age in Birthday reminder
Post by veganchris »
i have new problems with the birthday-reminder too. in the reminder it's totally wrong, but on the today-screen it's right:
veganchris
will this be repaired in EssentialPim 3.7?
PeCe
Has thanked: 101 times
Been thanked: 345 times
Post by PeCe »
It would be nice if this error would be corrected. But unfortunately the RC3.7 still has the same problem and displays a wrong birth date.
Has thanked: 1616 times
Been thanked: 1134 times
In order for the birthdays to display correctly you need to re-create them with EPIM 3.54 or newer version. An additional fix will also be included in the next release of EPIM. Sorry for the inconvenience.
veganchris
admin wrote:In order for the birthdays to display correctly you need to re-create them with EPIM 3.54 or newer version. An additional fix will also be included in the next release of EPIM. Sorry for the inconvenience.
i've done this, and it got worse afterwards... sorry
Please try EPIM 3.7 RC2, we've implemented some changes with regards to this issue. Should be ok now.
veganchris
do i have to delete and enter all birthdays once again? until now there's no real change...
Please do that with at least couple of birthdays and then see if it works for you.
veganchris
i've done this with the next birthday ( 20.8 ) and wanted to be reminded today, and it still is wrong - 20.8.2019 - 9 years (it's my mothers birthday)
PS. if i clear the birthday-field, saving it, and entering it afterwards again, then the number of days to get informed before is already filled with "200"...
kaigan
Post by kaigan »
veganchris wrote:i've done this with the next birthday ( 20.8 ) and wanted to be reminded today, and it still is wrong - 20.8.2019 - 9 years (it's my mothers birthday)
I've been trying to reproduce this error and haven't been able to till tonight. Started EPIM 3.7 RC2 and reminder came up for a birthday and it was as above. The birthday for this person in contacts had been deleted and re-entered.
Thank you all for your input. Can once again confirm the issue. It will bi fixed in the final release of 3.7 version.
