Field "LanguageID" in .lng files ?
- Golfy
- Has thanked: 14 times
- Been thanked: 26 times
I would to correct this in french.lng if it's not right : actually LanguageID=0c
Microsoft says : http://msdn.microsoft.com/library/defau ... s_61df.asp
So, LanguageID=040c ???
Code: Select all
0x0c0c Canada (CA) 0x03 SUBLANG_FRENCH_CANADIAN
0x040c France (FR) 0x01 SUBLANG_FRENCH
0x140c Luxembourg (LU) 0x05 SUBLANG_FRENCH_LUXEMBOURG
Re: Field "LanguageID" in .lng files ?
Are there many differences in between these 3 variations? If not, then we could just keep the original ID.
- Golfy
I hope so no... but as I'm french from France, I prefer to use France ID code.
Like this, canadians wouldn't says "the translator is bad"
(for example, in France email could still "email" rather Quebec and French canadians would prefer "courriel")
As I wouldn't offend or hurt anyone, I thinks it's better to put the right code and if a canadian's guy want to arrange translation for Canada, he could do that with the right code for him.
Thanks for your answer
Okay, got you. Some changes might be needed with EPIM in order for the new system to work. Meanwhile, please leave the language ID as it currently is.
