G'day folks ...
I use EPIM Notes to record a daily journal. Today, after writing a heap of stuff for Friday 3 February, I must have hit a key (blaming myself because I don't believe what happened was a bug) and all my entries for February disappeared - some of them pretty important.
So I tried the "undo" feature without success. I then tried to open the backup database whose date and time was just before the problem above occurred. It didn't open and the following message was displayed:
The procedure entry point ?countFactories@ICUService@icu_3_0@@IBEJx2 could not be located in the dynamic link library icuuc30.dll.
I clicked on ok and the message blinked on again with a further message saying "EPIM not responding" so had to click on "end process".
Any clues how to recover? Is this a bug?
EPIM 4.53 Notes
Re: EPIM 4.53 Notes
what module do you use to make a daily journal? As far as I can see, Undo works almost everywhere.
As regards restoring backup- that's a good idea. For that, download a Portable Free version and install it into a separate folder, then open it and open backup file from this version of EPIM.
Re: EPIM 4.53 Notes
Hi Max,
Did exactly what you suggested but when I tried to open the backup file it failed with the same message as in my first post, Entry Point Not Found, except the last 3 letters were JXZ. When I click on the OK button, the message blinks and reappears. The only way to stop it is to kill the program.
In notes I create a file for each month, then add my journal entries. I have 5 years worth. I use my journals to create a monthly newsletter.
Cheers,
Ken
Cheers,
Ken
I'm not a complete idiot - several parts are missing.
Re: EPIM 4.53 Notes
This is strange. Does it happen to every backup? We can try to fix the database if needed, you can send it to ma@essential...
Re: EPIM 4.53 Notes
Thanks Max. Yes it happens with all the backups I tried. I've recreated the entries I made from memory (which means less than half the original ).
In future I will keep a copy of the database on my portable version.
Thanks for trying anyway.
Cheers
Ken
Cheers
Ken
