Labels
I have found these, if it is any help:
http://www.rippedsheets.com/avery.php
http://www.worldlabel.com/Pages/popular.htm
http://www.onlinelabels.com/averycmp.htm
avery mail labels sizes official chart in pdf
this is the official list, I download it from avery, reference url is:
http://www.avery.com/us/products/catalog/index.html
also I need print a full contact info but when I send to the printer I only have name and phone, can I fix that to print the full adress and other info?
Regards william
Regards william
William Galindo
Re: avery mail labels sizes official chart in pdf
using these numbers is like trying to build a car based on its technical characteristics...There is a special list for developers.galindox wrote:this is the official list, I download it from avery, reference url is:
Yep, after you select File-> Print, you have a small dialog, where you can select the fields to print. By default only those fields are selected that are shown in your main view of contacts.galindox wrote: also I need print a full contact info but when I send to the printer I only have name and phone, can I fix that to print the full adress and other info?
Regards william
I.e. you have only Name and Phone showing in EPIM.
