Feature suggestion: date/time stamp
Mel
Has thanked: 9 times
Been thanked: 9 times
Post by Mel »
I would appreciate new shortcuts available in Options/Shortcuts/Global that would work in every EPIM field:
Insert date
Insert time
in user-definable format be it YYYY-MM-DD HH:MM:SS or whatsoever else.
Thank you,
-- M.
Re: Feature suggestion: date/time stamp
Thank you, your suggestion noted.
hannibal_barca_1974
Has thanked: 6 times
Been thanked: 4 times
Post by hannibal_barca_1974 »
Might we introduce the format (example) Fr 16/11/12 15:25:35? This only requires the addition of day in 2 digit format ie Mo, Tu, We, Th, Fr, Sa & Su. Thanks.
mithcd
Post by mithcd »
Format options should be available and easy to develop. I hope this gets implemented. Image
This feature is available now in EPIM 5.57.
