Import .rtf InfoSlect
xcyclone
Post by xcyclone »
After doing a note transfer from Info Select to EssentialPIM, most were accepted in total, but some had the type covered and shown as Black. Under the black the type was there but how do I remove the black cover?
The only issue thus far............would have like to show the subnotes under each subject as a tree as in Info Select, but hope for the furtuer I can do this.
The .rtf for the few exceptions when fine...................to bad I could not do all notes that way but it would take to much time.
Next step is to sync with Android................hope that works.
Brjlk
Re: Import .rtf InfoSlect
Post by Brjlk »
Hi, out of curiosity it went to the Infoselect site. But since last week it is not available. Seems it is discontinued.
Brjlk
