opening screen
AREFTEE
opening screen
Post by AREFTEE »
i just installed EPIM on my desktop and Droid X and performed a sync, but the opening screen on the Droid only shoes "To Do", Notes. Where is Contacts and Calendar
Has thanked: 1616 times
Been thanked: 1135 times
Re: opening screen
What's the Android app version? You can find it in Menu->Settings->About.
PeCe
Has thanked: 101 times
Been thanked: 345 times
Re: opening screen
Post by PeCe »
If you just downloaded and installed these programs, than it should display, calendar, passwords, ToDo, notes and PC sync. Not only ToDo and notes. This applies for version 1.7.7
Contacts are synced, but still are stored in the Android contacts.
Older versions of EPIM for Android did sync with the Android google calendar.
So please check your EPIM Android version.
