Sync from within Android?
I use the portable version of EPIM on my PC. The program and database are stored under My Documents.
All My Documents are being sync'ed to my Android.
So isn't there a way to sync the database which is in My Documents on Android with the EPIM Android app?
- Been thanked: 1135 times
Re: Sync from within Android?
EPIM Android APP will not work with the database file from Windows version of EPIM. Android EPIM stores all its data in the native Android database, which is considered to be much faster and more reliable on this particular system.
