Access vioaltion at address in EssentialPIM with OwnCloud
I´m trying to use EssentialPIMProPortable to check if this will syncronise my PC, Laptop an Android-Smartphone with my own ownCloud-server.
If I sync from EPIM-Portable to ownCloud (1- and 2-way-sync) I get this error message (look at screenshot). It is when less than 50 % are syncronized.
What can I do?
Michael
What can I do?
Michael
- EPIM-Fehler2.png (13.49 KiB) Viewed 3020 times
Re: Access vioaltion at address in EssentialPIM with OwnClou
if it is a public service, please tell its name. If not, please tell owncloud version number.
It´s not public. There is ownCloud 5.0.3 installed.
I've created a test account. How could I send it to you? This und the address? I don't wanna post it here
Thanks Michael
Thanks Michael
Re: Access vioaltion at address in EssentialPIM with OwnCloud
Meanwhile Owncloud 7 was released. EPIM Cloud uses Owncloud 7.x and works without such errors. So please clarify with logs, screenshots and version numbers what problem do you mean exactly.
