Improvement in To Do
I have a suggestion to improve the To Do module: the filters options that were chosen could be automatically saved, so every time I start EPIM it would not be necessary to set the desired filters again. Even better, could there be an option to turn on or off such feature.
Regards,
Christhiaan
Regards,
Christhiaan
Re: Improvement in To Do
It will be good to create a To Do and assign it to Notes or create a To Do in Notes .
- Has thanked: 2 times
- Been thanked: 63 times
Hello Efkan,
Have you ever considered using an hyperlink pointing to your required EPIM item ?
Works great !
Works great !
NormTheStorm
Win10 Home Version 22H2 (OS Build 19045.5737) 64-bit, 8 GB RAM, EPIM Pro Life 12.2 (Build 1034)
