I'm having a problem syncing from desktop to iphone: I have a lot of recurring events - e.g. 1st Sunday of every month.
When I sync to iphone, most are repeated on the date of the first entry (e.g. 7th) not the day (Sunday)
So event first entered on Sun 7th Dec is repeated, not on Sun 4th Jan and Sun 1st Feb, but on Wed 7th Jan and Sat 7th Feb.
Some aren't being repeated at all.
Any suggestions please?
I'm using an iphone 3gs iOS 6.1.6
EsssentialPim for iOS v 2.7.12
Windows 7 32-bit
EssentialPIM Pro 6.05
Sync to iphone - recurring events on wrong date
Re: Sync to iphone - recurring events on wrong date
Hello Max
Same problem here. Win 7, epim pro 6.05, iphone 5, ios 8.1.3, epim ios 2.7.12. Setup new test appointment for the first Sunday of every month starting Sunday 3/1/2015
Desktop shows
3/1, 4/5, 5/3, 6/7, 7/5, 8/2, 9/6, 10/4, 11/1, 12/6/2015
Iphone shows
Sun Mar 1
Wed Apr 1
Fri May 1
Mon Jun 1
Wed Jul 1
Sat Aug 1
Tue Sep 1
Thu Oct 1
Sun Nov 1
Tue Dec 1
Fri Jan 1 2016
Hope this helps
Lee S
Desktop shows
Iphone shows
Sun Mar 1
Wed Apr 1
Fri May 1
Mon Jun 1
Wed Jul 1
Sat Aug 1
Tue Sep 1
Thu Oct 1
Sun Nov 1
Tue Dec 1
Fri Jan 1 2016
Hope this helps
Lee S
Has anyone got a solution to this, please? Or is it a known issue that is being addressed? It's really frustrating - makes epim almost unusable on my iphone. ![Sad :(](./images/smilies/icon_sad.gif)
I find it hard to believe that there has been NO RESPONSE from the support group on this for ONE MONTH. Have been exceptionally pleased with EssentialPIM for many years and find this unusual. Perhaps lost in the shuffle or I missed something.
Thank You
Lee S
Thank You
Lee S
Hello guys,
thank you for reminding about the issue. Will look into this and try to improve for next 6.5 version.
Thank you - I look forward to being able to use this again!
Hello Max
On a chance I tried the test again with the 6.06 beta knowing it was primarily for the google problem. Got the same problem results as b4 with the 6.05 on 2/16/2015. Appears to me that the fix for this didn't make it into the 6.06 beta.
Lee S
Lee S
Yes, the fix is quite complicated, and will make it to 6.5 earliest. It was too risky to fix it in 6.06
Hello Max
Thank You for the update. Will look for it in the 6.5.
LeeS
LeeS
Hello Lee,
this fix should be in the 6.5 RC1 now. Could you please try?
Pro Desktop: http://www.essentialpim.com/download/be ... MPro65.exe
Pro Portable: http://www.essentialpim.com/download/be ... Port65.zip
