EPIM on Android
cowboy45
EPIM on Android
Post by cowboy45 »
I am attempting to use an android tablet to sync with my computer via dropbox.
It works between computers quite well, BUT
I have dropbox and EPIM both installed on the tablet, both appear to work BUT:
How do I tell EPIM where to find the file? The file is there,I just can't find the "open" command.
Help?
Re: EPIM on Android
Android EssentialPIM will not sync with Dropbox, only with Google services (Calendar and Tasks) and Windows EPIM.
cowboy45
Re: EPIM on Android
Post by cowboy45 »
I got it to sync without dropbox, and it looks right, but does it do it automatically, or do I need to tell both the PC and android to sync each time there is a change?
markfish
Re: EPIM on Android
Post by markfish »
Are there any plans to incorporate Dropbox support for Android?
Re: EPIM on Android
PC and Android sync needs to be initiated manually from within Android EPIM. If you sync with Google services, it happens automatically.
Support for Dropbox is not possible on Android due to different database file structures on both Windows and Android versions, unfortunately.
markfish
Re: EPIM on Android
Post by markfish »
Disappointing but understandable. It would be nice to be able to have some kind of mobile sync for when traveling. Keep the mobile and home pc updated automatically, you know? Not a fan of the google sync, although it would work in a pinch.
Re: EPIM on Android
We surely understand need for that kind of functionality. Already working on something along these lines.. Thanks!
markfish
Re: EPIM on Android
Post by markfish »
That's good to hear. Thank you and keep up the good work.
