Upgrade to 7.22 does not complete
vblansh
Has thanked: 10 times
Been thanked: 5 times
Post by vblansh »
I am considering to upgrade to a PRO version but two problems still hold me back:
#1
at the moment I am using a free version 7.2
Trying to upgrade to a new release 7.22 starts automatic upgrade but does not finish. After it closes PIM for a reboot, reboot does not happen and when I manually open PIM - it is still v. 7.2
My system is Windows 7 Ultimate x64 bit with intel Core i5
Another problem with EPIM:
dragging a link from the latest Firefox browser into PIM notes - EPIM closes and gone. If I just save to clipboard and then paste - it is working .
Is saving links (drag-and-drop) supported?
Thank you in advance
Vladimir
Re: Upgrade to 7.22 does not complete
Please download Pro 7.22 from here http://www.essentialpim.com/get-epim and just use the normal install.
I could not reproduce the problem with Firefox and EPiM Free 7.22 and dragging links. Can you maybe make a video, demonstrating it?
vblansh
Post by vblansh »
Manual download from that link worked fine - thank you
vblansh
Post by vblansh »
Also with new version EPIM does not quit when dragging http link. It just enters web page title text into the note's body.
But it does not create link automatically either.
I just arrogantly assumed that it will make link by dragging from the browser. My fault.
I now see a "create link" icon which I have to choose to get a dialog box for inserting a link. Then pasting link into the http field...
This works as it was meant to...
Thank you
Vladimir
vblansh
Post by vblansh »
Purchased pro version. Smooth installation.
Thank you
