EPIM 7.2 under Wine - issue in Notes
Hello -
using EPIM for years now, it always worked with Wine 1.6 on Linux. Downloading 7.2, it seems to work but "Notes" doesn't work anymore, when you start trying to type something in a note, text disappears and you can't type anymore...
Did anyone experience that ? I tried with Wine 1.9, same problem...
I would assume it comes from the implementation of "Notes module now has Back/Forward/History navigation buttons".
Yquux
Yquux
EPIM 7.13 (portable) daily use on Linux Mint 18.x (via Wine 1.6), Manjaro (via Wine 1.9) & Win7
Re: EPIM 7.2 under Wine - issue in Notes
I'm also been having some issues with 7.2 under Wine, but I haven't figured anything useful out yet... just figured I'd let you know you are not alone with 7.2 causing issues on wine. XD
For me though notes still work, but randomly I get this error well moving between notes: If I exit out of it 2-3x then I can use the note as normal (mostly the text courser has vanished entirely eg no blinking "|" anywhere in EPIM.).
Overall I really have no idea at this point what the issue could be or how to fix it.
I've moved back to 7.13 on my Linux system for now and am keeping a copy of 7.2 around to try and figure out anything worth sharing when I have the time.
Same issues with 7.21 -
Yquux
Yquux
Hello guys,
can you post maybe a video of the issues? Hopefully it will give us idea of what's going on under Wine.
Hello !
thank you for your interest for linux users !
Here is a video - I am happy to help more if needed - EPIM 7.2 under Wine 1.6 - Linux Mint Cinnamon 18.1
https://framadrop.org/r/nrAAW3N7IK#njbK ... UPLT0EgkQ=
Yquux
Yquux
Same issues with 7.22 - (tested only under wine 1.6 - wine 2.0 is coming soon - I'll check too)
Yquux
Yquux
Same issues with 7.23 with Wine 2.4 (on Manjaro).
Yquux
Yquux
Video https://framadrop.org/r/nrAAW3N7IK#njbK ... UPLT0EgkQ= is not available
