Trying to sync EPIM Pro 7.24 with Outlook 2013 on Windows 10 64bit.
Mapi error 80040111
Mapi error 80040111 - EPIM Pro 7.24 on Outlook 2013 [Solved]
Re: Mapi error 80040111 - EPIM Pro 7.24 on Outlook 2013
for synchronization with Outlook 64bits please use EPIM-Outlook Sync application from here: http://www.essentialpim.com/get-epim
- Beta Team
- Been thanked: 2 times
My Outlook version is 32bit running on Windows 10 Pro 64bit.
Should i install from that link just the same?
-Dan
EssentialPIM Pro should be working with Outlook 32 bit. If it does not, please provide more information, such as synchronization log and screenshot.
- Beta Team
Re: Mapi error 80040111 - EPIM Pro 7.24 on Outlook 2013 [Solved]
Did this fresh install without trying option for Outlook "exchange server".
It's okay now, my apologies.
-Dan
Same error. But I use portable version.
