issue to sync outlook help please
- Has thanked: 7 times
- Been thanked: 2 times
Hi
i use the last version of essentialpim pro & pro portable
well i create an new sync with outlook.com , web email
if i enable sync task
i get this error
can i fix it? how can i fix it?
it works perfectly with google account but with oulook.com i have this error when i want to sync Task , calendar works
thanks
i get this error
thanks
Re: issue to sync outlook help please
please:
1. install latest actual verison- 7.6 RC1: viewtopic.php?f=1&t=19641
2. go to File-> Database management and clear cache for the Outlook synchronization and try to synchronize again.
If that does not help, please send logs:
enable extended logging in Tools-> Options-> Synchronization, perform the synchronization and then get log for faulty synchronization using Tools-> Options-> Synchronization-> Browse and send it to epimsupport@... describing the problem and with a link to this forum topic
please:
hiMax wrote: Sun Oct 22, 2017 9:57 pm Hello,
please:
thank you so much it works!!!!
i have installed the last version
but sometime when i close essentialpim ,they sync don't start even i setup to sync when i close the program
thanks
Please describe what synchronizations you expect to start (and they do not). Please also tell exactly which setting you have set up (that syncs when you close program)
