EPIM Synchronizer error
shigue
Post by shigue »
Hello!
I tried to use EPIM Synchronizer program, but there is an exception when i execute this program and the send log option is useless. In the end, the file size from the synchorinzed files are different from each other.
Follow the exception log:
"Too many concurrent executions of the same request
At procedure 'NOTEHASPARENT' line: 12, col: 3
At procedure 'NOTEHASPARENT' line: 12, col: 3"
Exception log with detailed tech info. Generated on 27/07/2017 11:55:08.
Application title: EPIM Synchronizer
Application file: C:\Program Files (x86)\EPIM Synchronizer\EPIMSync.exe
Application: EPIM Synchronizer 7.5
Exception message: Too many concurrent executions of the same request
At proce..
Exception address: 00656398
Main thread ID = 10728
Exception thread ID = 10728
1191935906 ExceptionDialog TextMemo
1191928765 StatusForm
1191928265 MainForm SyncBtn
1191652734 MainForm SyncZap1
1191633718 StatusForm
1191631218 MainForm SyncZap1
1191623531 ExceptionDialog SendBtn
1191610843 ExceptionDialog OkBtn
1191610765 ExceptionDialog TextMemo
1191590171 StatusForm
Exception stack
Stack list, generated 27/07/2017 11:55:08
[00656393] IB.IBDataBaseError (Line 420, "IB.pas" + 39)
[0067D036] IBDatabase.TIBTransaction.Call (Line 1665, "IBDatabase.pas" + 11)
[0066B44E] IBSQL.TIBSQL.Call (Line 2491, "IBSQL.pas" + 3)
[0066B7C4] IBSQL.TIBSQL.ExecQuery (Line 2564, "IBSQL.pas" + 50)
[007A27CD] SyncObj.TNote.StoreToSQL (Line 5909, "SyncObj.pas" + 13)
[007A2BB1] SyncObj.TNote.Store (Line 5961, "SyncObj.pas" + 10)
[007A3904] SyncObj.TNoteList.Store (Line 6124, "SyncObj.pas" + 8)
[0093EAEB] Sync.AutoSyncNotes (Line 1773, "Sync.pas" + 131)
[00947371] Sync.Synchronization (Line 4339, "Sync.pas" + 70)
[0094A848] Main.TMainForm.SyncBtnClick (Line 425, "Main.pas" + 88)
[0054E3B8] Vcl.Controls.TControl.Click (Line 7348, "Vcl.Controls.pas" + 9)
[005744F9] Vcl.StdCtrls.TCustomButton.Click (Line 5319, "Vcl.StdCtrls.pas" + 3)
[00575462] Vcl.StdCtrls.TCustomButton.CNCommand (Line 5780, "Vcl.StdCtrls.pas" + 1)
[0054DD61] Vcl.Controls.TControl.WndProc (Line 7232, "Vcl.Controls.pas" + 91)
[005539B5] Vcl.Controls.TWinControl.WndProc (Line 10047, "Vcl.Controls.pas" + 153)
[00574032] Vcl.StdCtrls.TButtonControl.WndProc (Line 5156, "Vcl.StdCtrls.pas" + 13)
[0054D862] Vcl.Controls.TControl.Perform (Line 7010, "Vcl.Controls.pas" + 10)
[00553BA4] Vcl.Controls.DoControlMsg (Line 10116, "Vcl.Controls.pas" + 12)
[00554781] Vcl.Controls.TWinControl.WMCommand (Line 10391, "Vcl.Controls.pas" + 1)
[005F80C0] Vcl.Forms.TCustomForm.WMCommand (Line 6163, "Vcl.Forms.pas" + 3)
[005F4163] Vcl.Forms.TCustomForm.WndProc (Line 4394, "Vcl.Forms.pas" + 201)
[00552EF4] Vcl.Controls.TWinControl.MainWndProc (Line 9759, "Vcl.Controls.pas" + 3)
[004CE8D8] System.Classes.StdWndProc (Line 16891, "System.Classes.pas" + 8)
[00553B2A] Vcl.Controls.TWinControl.DefaultHandler (Line 10088, "Vcl.Controls.pas" + 30)
[0054E90D] Vcl.Controls.TControl.WMLButtonUp (Line 7481, "Vcl.Controls.pas" + 1)
[005FF92B] Vcl.Forms.TApplication.ProcessMessage (Line 10234, "Vcl.Forms.pas" + 23)
[005FF97B] Vcl.Forms.TApplication.HandleMessage (Line 10264, "Vcl.Forms.pas" + 1)
[005FFD57] Vcl.Forms.TApplication.Run (Line 10402, "Vcl.Forms.pas" + 26)
[00995523] EPIMSync.EPIMSync (Line 29, "" + 5)
Memory: 4001; free 1206
Display : 1366x768 pixels, 32 bpp
PrevExceptions:
1191630984 Transaction is not active
Been thanked: 363 times
Re: EPIM Synchronizer error
thank you, we are aware of the issue- that will be fixed in forthcoming 7.53 version.
mguillien
Post by mguillien »
ou mentioned it was known and would be fixed in version 5.3 but I have version 6.2 and still face exactly the same problem.
Anything I can do?
The original post is about another error.
In your case, please re-create IMAP account and the issue might dissapear.
mguillien
Post by mguillien »
I did recreate the IMPA account but get the same error. I finally decided to use the PO3 version of the account instead, which works. Note that GMAIL IMAP works (although I face an other problem when trying to access on specific folder while all others work correctly).
