DB error on upgrade to 8.0 Pro
Hi, I upgraded to 8.0 (the message inside EPIM did NOT tell me this is RC only)
I the logged into the DB as an admin, as requested, to upgrade the database (over the LAN)
Then I get this
here was an error during the execution of this program.
unsuccessful metadata update
Column INLOGIN from table MAILACCOUNTS is referenced in MAILACCOUNTVIEW.
Weird thing, the "send" button is inactive
Details
Then I get this
Details
Code: Select all
Exception log with detailed tech info. Generated on 29/06/2018 9:44.
Application title: EssentialPIM Pro
Application file: D:\Utilities\EssentialPIM\EssentialPIM.exe
Application: EssentialPIM Pro 8.0 28/06/2018
Exception message: unsuccessful metadata update
Exception address: 0067CBD0
Main thread ID = 20352
Exception thread ID = 20352
Object Logs:
60929718 DBOpen
60728921 DBOpen
57650390 DBOpen
57611125 DBOpen
60931218 ExceptionDialog TextMemo
60926453 ConnectDialog GroupBox1 LoginCB
60922953 ConnectDialog FileCB
60919453 ConnectDialog ServerCB
60837453 MainForm
60831453 AboutForm OKBtn
60828453 MainForm
60730500 ExceptionDialog OkBtn
60730484 ExceptionDialog TextMemo
57664687 MainForm
Last Clicks:
60929625 MouseClick: ConnectDialog OKBtn
60926250 MouseClick: ConnectDialog GroupBox1 LoginCB
60923406 MouseClick: ConnectDialog FileCB
Memory: 16281; free 10015
Display : 1536x864 pixels, 32 bpp, 96 PPI
PrevExceptions:
57635484 unsuccessful metadata update
57664593 unsuccessful metadata update
60828250 unsuccessful metadata update
Stats:
MouseClick: AboutForm OKBtn 1
MouseClick: ConnectDialog FileCB 2
MouseClick: ConnectDialog GroupBox1 LoginCB 2
MouseClick: ConnectDialog OKBtn 2
MouseClick: ConnectDialog ServerCB 2
MouseClick: ExceptionDialog OkBtn 3
TBXItemClick: MainForm Panel0 TopPan TBXToolbar1 FileMI FileConnectMI 2
TBXItemClick: MainForm Panel0 TopPan TBXToolbar1 FileMI FileHistory1MI 2
TBXItemClick: MainForm Panel0 TopPan TBXToolbar1 HelpMI HelpAboutMI 1
TBXItemClick: MainForm Panel0 TopPan TBXToolbar1 HelpMI HelpSuppForumMI 1
Re: DB error on upgrade to 8.0 Pro
that was fixed in a silent update, please download it from: https://www.essentialpim.com/get-epim (even if you currently have 8.0 version)
If that does not help, please send us your database- so that we could fix it. You can send it to my email at ma@essentialpim... with a link to this topic, please.
