Solved. Bug: 8.0 no special characters, wrongly assigned shortcuts
- Has thanked: 17 times
- Been thanked: 43 times
I am really surprised, cannot work with 8.0, Win 10 x64 and Win 8.1 x64 same problem:
RightAlt + a starts Android sync,
RightAlt + z starts Google sync.
What it should do is putting Polish diacritic signs, as here:
ą, ż.
In Shortcuts everything is as previously, so I do not know what to change:
Alt+Ctrl+g is for Google sync and so on.
Please fix it, as it makes EPIM useless for now. I need to put the data correctly spelled.
Best,
Piotr
ą, ż.
Best,
Piotr
Win 10 Pro 64x
Win 10 Pro 64x
Re: Bug: 8.0 no special characters, wrongly assigned shortcuts
Changing language does not help. It is only for View purposes, Menu and so on.
And BTW, in Shortcuts there is no Alt+g or Alt+a, so something went wrong.
Win 10 Pro 64x
Win 10 Pro 64x
Workaround: I have disabled all shortcuts. Works.
Win 10 Pro 64x
Win 10 Pro 64x
Thanks for the info, will check and fix if possible.
Still nothing. Shortcuts work incorrectly, ie. non-assigned shortcuts replaced assigned ones, like above.
Can you revert to the "before 8.0" behaviour?
Win 10 Pro 64x
Win 10 Pro 64x
Please backup the EPIM.ini file, then delete it and start EPIM. That should solve the problem. Thanks!
Nice, solved, thank you!
Win 10 Pro 64x
Win 10 Pro 64x
