Adding Company & Employees
Hi, I am new to EssentialPim but previously used MaxiMixer CRM.
What is the best way to set up a Company and its employees in EssentialPim ?
Do I Create a Group and call it the company name eg "Paper Supplies Plus" and then add the employees as Contacts in this Group?
Is there a better way?
- Has thanked: 21 times
- Been thanked: 184 times
Re: Adding Company & Employees
it always depends what your goal is.
This is my way:
You can create "Groups" within your Adressbook. You can assign employees to the groups and sub-groups.This is one way to sort them.
You're also able to assign them to multiple groups and sub-groups.
please have in mind:
if you move a person to a sub-group, it is going to disappear in the group above. But all Contacts are visible in the main root directory.
To set the person visible it must be assigned to the group of the company, and the sub-group of it. (also if you have group - subgroup - subsubgroup)
This is my way:
*including RC`s
*including RC`s
Thanks for the response. Thats what I thought.
The only problem is that when you Add to contacts a new email address, unless the Membership Group has already been created, they cant be added to a new Group.
mmh, it's no problem?
1. I create a contact. I fill in some data.
2. then i assign this contact to a sub-sub-group
3. then i add an e-mail adresse to the contact
4. then i assign the contact to a diffrent sub-group
--> no problems
5. i also created a new group.. also no problems
--> no problems
*including RC`s
*including RC`s
- Has thanked: 17 times
- Been thanked: 43 times
Not quite.Texter wrote: Wed Aug 01, 2018 10:22 pm
If you just drag'n'drop a contact (a person), yes, it moves from one group to another. Which is by the way a great improvement since some time. So vanishes in one group, appears in the other.
But if you drag'n'drop with Ctrl pressed, then you just copy the assignment, ie. a person is visible in both groups, source and target.
The only weak point here is that a cursor does not change into the one with +, to indicate like in Windows that we copy something.
Win 10 Pro 64x
Win 10 Pro 64x
