drag&drop for email attachments
Kifo
Post by Kifo »
In past versions it was easy to attache files to an outgoing email using drag and drop. In the current version (7.13 Pro) this is no longer working. Why is this convenient feature gone? Any workaround?
BR
Kifo
Re: drag&drop for email attachments
in 7.2 RC2 it is possible to drag and drop attachment files to new mail window. You can get 7.2 RC2 here: http://essentialpim.com/forum/viewtopic.php?f=1&t=18774
geistLich
Has thanked: 7 times
Been thanked: 7 times
Post by geistLich »
what happened to this function? It is not working in Pro 8.1. Can't drop an item within the new mail windows. The only way is to use the open dialog - that's really bad. A lack in productivity.
Please restart EPIM, that should fix it.
Kifo
Post by Kifo »
On my V8.1 it works without problems.
geistLich
Post by geistLich »
Still not working. So, how to do it exactly? I restarted EPIM Pro. Go to E-Mail. Click on New Mail. Drag a file from desktop and go with the mouse over the window of the new mail. But on every part of this window the mouse-icon looks like "not possible". Even if I drop the file nothing happens.
Unfortunately at the moment I do not have a screenshot program installed which also captures the cursor.
Help - About says "EPIM Pro 8.1"
What if you restart your PC (Sing Out/Sing In should also do it), will that help?
geistLich
Post by geistLich »
I restart my pc every day, so that can't be the reason. I could try to create a new database and check this out there.
Yes, please do that. We were able to partially reproduce the issue but so far with no clear pattern..
geistLich
Post by geistLich »
Deleted my mailaccount from epim a week ago. Now added it today again and still no drag and drop.
Next try: Made new database and configured mailaccount. Still no drag and drop from within the window "new mail".
Which app are you trying to drop from? Also, please mention your Windows version.
