Hello everybody,
when syncing iCloud with EssentialPIM, I always get the error message HTTP/1.1 412 Precondition Failed.
I have noticed that the error only occurs when the calendars are synchronized. I disable the synchronization of the calendar and the message does not appear again. I really need the synchronization of the calendars, so disabling is not an option for me.
If I completely delete the iCloud synchronization and set up new, the first sync works without error message.
Thank you for your help!
EssentialPIM Pro 8.1, Lifetime, Windows 10
iCloud Sync: HTTP/1.1 412 Precondition Failed
Re: iCloud Sync: HTTP/1.1 412 Precondition Failed
I have same situation, too. Sync without calendar worked well, as you said.
But when I delete the icloud sync and re-login again, my first sync showed same error message.
Please help, Thank you.
