Wishes in Mail module
pela
Has thanked: 30 times
Been thanked: 21 times
Post by pela »
Hello
I would be glad, who in the mail module, export account and import could.
News goes, I'm missing the account.
and who is the same then, Pabierkorb, in the mail module, which one can adjust, that after certain days everything in it is extinguished.
translated with Google
With best wishes
Re: Wishes in Mail module
your suggestion is unclear, unfortunately.
pela
Post by pela »
Hallo
Mail Modul
E-Mail Konto
Fehlt Export der Konto
Fehlt Import der Konto
Modul Mail.
Bereich Papierkorb
Nachrichten nach Bestimmten Tagen Gelöscht werden. ( 1 oder mehrere Tage )
übersetzt mit Google.
Hello
Mail module
Email account
Missing export the account
Missing import the account
Module Mail.
Trash bin area
Messages are deleted after certain days. (1 or more days)
translated with Google.
thank you for clarification. Why do you want to export and import email accounts? How would you use it?
Regarding "Messages are deleted after certain days. (1 or more days)"- that feature might be soon coming.
pela
Post by pela »
Hallo
Danke das in naher Zukunft das kommt , wegen Papierkorb und Löschen automatisch
Wegen Konto Import und Export .
Ich bin es Gewohnt , das so Konto Sichern kann und wieder Import kann , wen wieder Lust habe das Mail Modul zu Testen. ( Habe im Moment noch Thunderbird im Haupteinsatz )
Müsste dann nicht , Konto Löschen und in Zukunft die Konto neu Erstellen.
Da Ich in Regel nach ca. 3. Neue Version von Epim , das Mail Modul wieder Teste
Um zu Schauen , ob Wechseln kann von Thunderbird.
Mit freundlichen Grüssen
Übersetzt mit google
Hello
Thanks in the near future that comes because of trash and delete automatically
Due to account import and export.
I am accustomed to be able to back up the account so I can import again who wants to test the mail module again. (I still have Thunderbird in the main application right now)
You would not have to delete the account and create the account again in the future.
Since I usually test after about 3. New version of Epim, the mail module again
To see if changing can be done by Thunderbird.
Yours sincerely
Translated with Google
a8907433
Been thanked: 170 times
Post by a8907433 »
Hallo pela,
Aber du mußt weder das Konto sichern noch löschen- du kannst einfach die alte Datenbank weiterverwenden! Du mußt kein Konto neu erstellen, wenn du wieder mal EPIM testest, nimm einfach deine alte Datenbank!!
Ich habe auch Thunderbird UND EPIM im Einsatz- aber ich denke, was das Mail-Modul betrifft, könnte ich schon auf Thunderbird verzichten (was die Zuverlässigkeit betrifft)- es fehlen nur noch ein paar Kleinigkeiten was die Bequemlichkeit betrifft.
a8907433
Post by a8907433 »
Translation for Max:
There is no need to delete your account- just use your database again!
I also use Thunderbird AND EPIM, but I think, I could go without Thunderbird, regarding reliability of the mail-module. Mail-Module is only lacking a few things regarding comfort.
pela
Post by pela »
Hallo
wegen alte DB
Da würden Mir aber immer , Sachen Fehlen. ( Kalender , Notizen und so weiter. )
oder Ich habe ein überlegungs Fehler.
Ich Benutze alle Module ausser das Mail Modul.( Mail Modul ,nur zum Testen. )
Notizen und Kalender jeden Tag.
Im Moment , könnte Ich noch nicht voll auf das Mail Modul , gehen.
Hat aber auch zum Teil , zu tun , wegen Kleinigkeiten und was die Bequemlichkeit betrifft.
MfG
Hello
because of old DB
But I would always, things missing. (Calendars, notes and so on.)
or I have a reasoning mistake.
I use all modules except the mail module (mail module, just for testing.)
Notes and calendars every day.
At the moment, I could not fully go to the mail module yet.
But also has to do in part, because of trifles and as for the convenience.
Kind regards
a8907433
Post by a8907433 »
Dann ist die Sache ganz einfach: In Tools/Account settings - auf Account klicken - Edit/Icnclude this account when receiving email - Häkcken entfernen. Dann bekommst du keine emails mehr. Wenn du noch in Tools/Options/Modules das Häkchen bei "Mail" entfernst, bemerkst du nichts mehr vom Emailaccount, es ist als hättest du keinen. Wenn du es rückgängig machen willst- einfach wie oben, nur umgekehrt....
pela
Post by pela »
Hallo
Das habe Ich auch schon Gesehen und überlegt , so vor zu gehen.
Das währe eine Lösung.
Ich habe aber immer so eine Macke.
DB so klein wie möglich
Lassen Wir das mal ruhen , und lasse Mich überraschen , wie es weiter geht mit dem Modul Mail.
MfG
