Crash report which cannot be sent by email?
- Has thanked: 15 times
- Been thanked: 3 times
EPIM (8.14, but also older versions) crashes sometimes and usually I can email the crash report. But some crashes result in more crashes when I try to send the email... Any idea what I can do to report such crashes?
Michael
Michael
Re: Crash report which cannot be sent by email?
when EPIM shows error, you can copy the content of the message and use another mail program/web interface to send it to epimsupport@essential...
No, I can`t. Email will crash over and over again. I could send a screenshot, but because two windows will overlap then (error message, email window), you won`t see much. If I try to move the email window - crash. At the moment I`m not aware of an easy screen filming tool, otherwise I could make a film...
I see. One of the free tools for screen recording we use is https://www.techsmith.com/jing-tool.html
Thank you! When you click on " Details", click inside the error text, select all, copy all and paste it into your e.g. gmail and send it to epimsupport@essential...
