[FIXED] Contact Sync hangs on "Batch storing contacts..."
Has thanked: 1616 times
Been thanked: 1134 times
Re: Contact Sync hangs on "Batch storing contacts..."
Bill, can you access the Developer options (in system settings) on your phone? If yes, will ask you to enable one option there and record a small video for us. Thanks!
With regards to the version number - it's the same 3.0.3, although build number is different (should probably make it visible).
kb5cth
Been thanked: 19 times
Post by kb5cth »
Admin,
Yes, I can access the developer options. I don't have decent video capability though. If you can describe what you're looking for, I can tell you whether it happens or what transpires.
I just tried running the month widget again: restoring home page *occasionally* takes 2 seconds. Mostly what happens, very repeatedly, is that you'll swipe your finger to change home page, nothing happens, you pause briefly, then the page changes. There is a distinct delay both in changing home pages, and in displaying the home page from the close of an application. That delay varies.
Bill
KB5CTH
Good, Bill, please check you personal messages here in the forum.
hocken24a
Post by hocken24a »
v3.0.3-preview seems to have fixed the contacts sync problem for me. works on both 4.1.2 and 4.4.2 for me. First batch one-way sync missed 2 contacts out 444, but follow-up sync quickly fixed what was missed in the batch sync.
Thanks very much for the confirmation, appreciate it!
Nurgotora
Has thanked: 4 times
Been thanked: 15 times
Post by Nurgotora »
Hi admin,
admin wrote:People who wish to test yet another update, please download it from this post. You might also notice performance improvements with the Month widget :) Would appreciate your feedback, thanks!
The 3.0.3 pre2 from Thu Mar 20, fixed the contacts sync problem on
- EssentialPIM Pro 5.57 Network; Windows 7 Prof 64bit
<=> EssentialPim Android free 3.0.3 pre 2; Android 4.1.2, Samsung Galaxy Note 10.1 (GT-N8000)
Thank you,
Nurgotora
Nurgotora, thanks for the confirmation! An update with this and other fixes, optimizations and improvements will be officially released in couple of days.
Nurgotora
Post by Nurgotora »
I am sorry to report that Sync with Contacts is still, well, unstable with
- the 3.0.3 pre2 from Thu Mar 20 and EssentialPIM Pro 5.57 Network; Windows 7 Prof 64bit
- (repeated and erratic) Access violation:
Code: Select all
2014.03.31 14:11:32.845   Client 192.168.1.50 connected
2014.03.31 14:11:32.846   Received message from client
2014.03.31 14:11:32.846   InfoReceived
2014.03.31 14:11:32.947   Requesting contacts...
2014.03.31 14:11:32.947   XML Parsed
2014.03.31 14:11:32.963   Received message from client
2014.03.31 14:11:32.963   XML Parsed
2014.03.31 14:11:32.963   Requesting data...
2014.03.31 14:11:33.988   Received message from client
2014.03.31 14:11:33.997   XML Parsed
2014.03.31 14:11:33.997   Requesting data...
2014.03.31 14:11:34.876   Received message from client
2014.03.31 14:11:34.883   XML Parsed
2014.03.31 14:11:34.883   Requesting data...
2014.03.31 14:11:35.808   Received message from client
2014.03.31 14:11:35.816   XML Parsed
2014.03.31 14:11:35.816   Requesting data...
2014.03.31 14:11:36.721   Received message from client
2014.03.31 14:11:36.730   XML Parsed
2014.03.31 14:11:36.730   Requesting data...
2014.03.31 14:11:37.608   Received message from client
2014.03.31 14:11:37.616   XML Parsed
2014.03.31 14:11:37.617   Requesting data...
2014.03.31 14:11:38.490   Received message from client
2014.03.31 14:11:38.499   XML Parsed
2014.03.31 14:11:38.499   Requesting data...
2014.03.31 14:11:39.441   Received message from client
2014.03.31 14:11:39.451   XML Parsed
2014.03.31 14:11:39.451   Requesting data...
2014.03.31 14:11:40.359   Received message from client
2014.03.31 14:11:40.369   XML Parsed
2014.03.31 14:11:40.369   Requesting data...
2014.03.31 14:11:41.242   Received message from client
2014.03.31 14:11:41.252   XML Parsed
2014.03.31 14:11:41.252   Requesting data...
2014.03.31 14:11:42.151   Received message from client
2014.03.31 14:11:42.162   XML Parsed
2014.03.31 14:11:42.162   Requesting data...
2014.03.31 14:11:43.089   Received message from client
2014.03.31 14:11:43.100   XML Parsed
2014.03.31 14:11:43.100   Requesting data...
2014.03.31 14:11:43.956   Received message from client
2014.03.31 14:11:43.967   XML Parsed
2014.03.31 14:11:43.967   Requesting data...
2014.03.31 14:11:44.868   Received message from client
2014.03.31 14:11:44.879   XML Parsed
2014.03.31 14:11:44.879   Requesting data...
2014.03.31 14:11:45.245   Received message from client
2014.03.31 14:11:45.250   XML Parsed
2014.03.31 14:11:45.252   ContactsSync
2014.03.31 14:11:45.263   ContactsCount=659
2014.03.31 14:11:45.266   ContSyncInfoCount=659
2014.03.31 14:11:45.337   AnSContactsCount=659
2014.03.31 14:11:45.340   NewItems.Count 0
2014.03.31 14:11:45.341   Copy3 8455475520720544 1364
2014.03.31 14:11:45.348   Error: Access violation at address 00DEDA7F in module 'EssentialPIM.exe'. Read of address 00000064
2014.03.31 14:11:45.348   Disconnecting client...
2014.03.31 14:11:45.351   Client 192.168.1.50 disconnected
Added / Changed Contacts get not synced to Phone - even with Sync data cleared - after such an exception with the next (successfull) resync. They have to be edited again.
Please enable the extended logging feature (in Tools->Options->Synchronization) and forward us that log file. You can send a PM to me with the file here in the forum.
ronkral
Post by ronkral »
I was having the SYNC problem with contacts also.
I downloaded and installed 3.0.2.
This SOLVED the Sync problem with CONTACTS,
but NOW it hangs syncing EVENTS/CALENDAR.
Better, but no cigar.
Ron Kral
ronkral
Post by ronkral »
Addendum - the CONTACT synch "works", but uploads the wrong data...
One of the people I have in ePim as "Starred in Android" does NOT
appear in my "Favorites" list... Looks like there's more work to do.
Ron, you should probably wait a bit and let the calendar sync to finish. If you have lots of appointments, the first sync could take up some noticeable amount of time.
With regards to the "Favourites" list - did it work before?
Nurgotora
Post by Nurgotora »
admin wrote:Please enable the extended logging feature (in Tools->Options->Synchronization) and forward us that log file. You can send a PM to me with the file here in the forum.
Sent you the extended log
Steps to reproduce
- Clear Sync data
- Uninstall EssentialPim on Android
- Install EssentialPim 3.0.3 pre2 (see above)
- Sync: Success
- Edit a contact in Windows Client
- Sync: Access Violation
Nurgotora
Post by Nurgotora »
Additional Info:
Bad news: Same effect with EssentialPIM for Android 3.0.4 (free)
Good(?) news: This (the Access violation) bug is a reproducable and definitely a completly different bug concerning Contact entries (on Android) "containing information from several accounts" I'll open up another Thread describing this in detail.
Thanks for the log, got it. Will update on the status of the issue.
