EssentialPIM 3.0 Public Release Candidate 3
csandman09
Re: EssentialPIM 3.0 Public Release Candidate 3
Post by csandman09 »
some findings:
Today-Screen, clicking on ToDos result in switch to Todo-Panel, but not to the correct Tab in ToDo-Panel; if you have some tabs in ToDo-Panel, you won't always see the todo, you clicked on today-Screen - please change to automatically switch to the correct tab
Adding contacts to Todos: if you have three contacs a, b, c and you add them in 2 phases, f.e. 1) b, then 2) a, save, then again add c, the result won't show this order - they get mixed - i would prefer as i result the order, i added them
Printing Task from Task-Panel doesn't start Print - nothing happens but system (epim) gets slower
Regards
csandman
Sorry, could you explain:
"Printing Task from Task-Panel doesn't start Print - nothing happens but system (epim) gets slower"- steps, what do you do?
csandman09
Max wrote:Sorry, could you explain:
These are the steps:
Taskpanel shows 3 tabs, each of them containing a task tree (using german localization i selected Aufgaben)
Using File ! Print ! selected printer in dialog box "send to OneNote 2007", Printing all, Print as Organizer (A5), hit ok-Button -> Result: nothing happens
if i do the same with calendar view in week view mode (german Kalender, Woche), selecting Druckvorlage Wochenansicht and printout as organizer, it works fine
if i do the same ... but without selection printout as organizer, again nothing happens
doing the same with a real printer (instead of sending to OneNote 2007 printer driver) works fine
tried under Win Xp2 SP2 and under Win Vista with Epim V3RC3
Yours
csandman09
noaccess
Post by noaccess »
В заметках некорректно работает поиск.
Например, в заметках есть слово "Поиск", ввожу его в поисковой строке в правом верхнем углу и не вижу результата, и только после переключения с "Все поля" на "Только содержимое" заметки выводятся нормально.
Yours
csandman09
Looks like the problem is with OneNote printer rather than EPIM.
csandman09
Yours
csandman09
Might be a problem of OneNote Printer Driver.
But all other software works fine with OneNote. EPIM is the singleton!
And - what counts more:
calendar view in week view mode (german Kalender, Woche), selecting Druckvorlage Wochenansicht and printout as organizer works fine with OneNote Printer Driver.
So please check your code, if you like.
Best regards
csandman09
