EssentialPIM 3.5 Release Candidate 1
Re: EssentialPIM 3.5 Release Candidate 1
Thank you, all noted. As regards "Debugger" problem- most probably the computer you tried it on has a debugger and EPIM protection does not like debuggers:), like many other programs, by the way.xman_by wrote:Thank you for the new version! I've just almost decided to buy it :)
Some notes:
1. I was a bit disapointed having found out that there's no possibility to set multiple tags (colors) to tasks/notes. I hope it will be soon. If it's difficult to realize quickly you could add an advanced search which allows AND and OR operations (thus we'll be able to point out what about our note or task is and use search instead of filtering: for instance, I can title my task as 'Phone John [tags: business, project1, phone]' and use search phrase like 'business AND phone' in order to see this task in results).
2. I tried you program at my friend's pc and it showed me an error when I was trying to save/open my database. It was saying that I have some debugger on my computer :(
3. It would be nice to see a DATE field for notes and a possibility to sort out a notes list as well as tasks list.
4. Emails gouped by topic/sender - still looking forward to :)
Max wrote:
2- UPDATE. Looks like you did not renew the language file.
Thank you, that solved the problem!
Downloaded the portable version. After 10 minutes playing around it freezed and could be closed only with task manager. After restarting it immediately freezed again.
Try with a new database to figure out whether the problem is with a particular database (which is also a problem of course) or with EPIM?PePan wrote:Downloaded the portable version. After 10 minutes playing around it freezed and could be closed only with task manager. After restarting it immediately freezed again.
I hope this is the right board to post this. I was very excited to see that I can sync with my Google Apps contacts only problem is the login info windows doesn't allow me to enter my full email address(options, Sync, Google). Can you increase the number of characters allowed in the email field please?
Switched from V3.21Pro to V3.5RC1 Pro. Google sync gives error "List Index Out Of Bounds (15)" Not sure what the error is.
The global cross linking is awesome. I now can link To Do to Notes for project support information.
So far , no problems. Waiting for the U3 version but working with the portable one just fine.
Kudos.
Kudos.
The new features look great, but one that is VERY important to me is still missing and keeping me from fully using Epim Pro. That is GLOBAL SEARCH. I really need to be able to search for a term and find instances of it whether its in a task, event, note or where ever. Do you think this will be possible anytime soon?
Paul
Paul
- petrsimanek
- Has thanked: 19 times
- Been thanked: 11 times
To pmlabrier: The global search was discussed here
viewtopic.php?f=3&t=8733
I agree that global search would be one of most important features.
Petr Simanek
EPIM user since April 2006, Beta Team member, always uses the latest stable and beta/RC version under Windows 10 Pro
Thank you. Yes, that's a known issue. Will fix.thomson wrote:Switched from V3.21Pro to V3.5RC1 Pro. Google sync gives error "List Index Out Of Bounds (15)" Not sure what the error is.
Go to Options, Schedule and chose 14 days to display.pandeng wrote:- 2-week view in Schedule
how to get the 2 week view?
OK, will do so.viisii wrote:I hope this is the right board to post this. I was very excited to see that I can sync with my Google Apps contacts only problem is the login info windows doesn't allow me to enter my full email address(options, Sync, Google). Can you increase the number of characters allowed in the email field please?
Hey max,
Sorry i didn't have time to read this whole thread but i have a problem:
- My google calendar sync (with contact sync on and off tested) to one calendar does not work anymore. Happened right after i upgraded.
EPIM to Google does not work, google to epim works.
Hi,ampedq wrote:Hey max,
I just created a simple Task for today in EPIM and synchronized with Google- and it appeared in Google. Can you do the same test?
