How to make Synchronization work with Windows Mobile devices
Re: How to make Synchronization work with Windows Mobile devices
Hmm. I've just my HD2 to 1.66 (from 1.48) and I can no longer get EPIM to connect. Activesync works, EasySync works, MyMobileR doesn't work.
I've tried all but the most long-winded solution outlined here.
- Been thanked: 1134 times
You should try the 3-rd method. It has been proven as the most effectvie one. Thanks!
I'd already tried 1,2 and 3 before I posted - it was the fourth option I really didn't fancy!
The details are hazy now as it was very late last night, but method 3, for some reason that my memory has erased because it was such a nightmare, caused me to either restore a backup, or re-flash and restore the backup. Anyway, after all that it didn't work, and it definitely wasn't working this morning.
But it's working now
What did I do? I rebooted my XP machine this evening. Wasn't expecting that!
Thanks for your response, BTW.
After upgrade form EPIM prortamble 3.51 to 3.52 I become message: "Your device was not detected. Please make sure the cable is plugged in securely"
I have PDA with Windows Mobile 2003 SE. (XP home SP3)
So what should I do now?
Hi,nandi wrote:After upgrade form EPIM prortamble 3.51 to 3.52 I become message: "Your device was not detected. Please make sure the cable is plugged in securely"
there is a problem with Windows Mobile 2003 at the moment in 3.52 version. We are working on that.
How can I downgrade database to version 3.51 form 3.52?
(wm 2003 se syncronization)
it is not possible, unless you have a 3.51 backup. EPIM makes backups automatically, so maybe you have this one.
Thanks for version 3.54. Now is possible syncronisation with my (wm2003 se) PDA.
Sycronization problem with PDA - Windows Mobil 2003SE
PPCSYNC.dll from: viewtopic.php?f=1&t=9226
EPIM PRO Portable 3.7
Calendar, Contact, To Do sycronization OK.
Prtoblem with notes:
1. New notes item in PDA
2. Syncronization
3. EPIM: OK, PDA:OK
4. Notes (1) editing in EPIM
5 Sycronization
6. EPIM: OK. PDA: Notes length 0 byte or Notes unreadable: ?????????????????
1. New Notes in EPIM
2. Syncronization
3. EPIM: OK. PDA: Notes length 0 byte or Notes unreadable: ?????????????????
2. Syncronization
3. EPIM: OK, PDA:OK
5 Sycronization
2. Syncronization
What are the contents of new notes that cannot be synchronized?
It's egal. With all new normal txt content is the same problem. And fast all old content.
You type your notes in English in EPIM, there's no Unicode in them?
I type my notes in Hungarian with with codepage windows-1250.
Wint english notes is same problem.
After backuping my notes i deletet all notes.
Making 1 new note:
content: note 1
After syncronizing in PDA the same problem. In EPIM note readable, in PDA "n1" is OK, but content only many "?" character.
The problem is new with version: EPIM portable 3.7
The syncronization problem only with notes.
Making 1 new note:
content: note 1
Making 1 new note:
content: note 1
After syncronization the note from PDA in attachment.
content: note 1
- n1.zip
- (122 Bytes) Downloaded 414 times
Thanks! Will try to reproduce and fix.
