<Simplified Chinese> Language file
Re: <Simplified Chinese> Language file
updated with EPIM 6.0.1
- Chinese_Simpl.lng
- For EPIM 6.0.1
- (59.25 KiB) Downloaded 506 times
for EPIM 6.02
- Chinese_Simpl.lng
- A micro error has been modified
- (59.69 KiB) Downloaded 560 times
For EPIM 6.54
- Chinese_Simpl.lng
- For EPIM 6.54
- (60.76 KiB) Downloaded 535 times
I've lost my password for a long time. And now I'm back.Here is the latest language file for EPIM 6.57 with a tiny bug modified. Pls check the file attached.
- Chinese_Simpl.lng
- For EPIM 6.57, a tiny bug modified.
- (60.8 KiB) Downloaded 458 times
- Has thanked: 1639 times
- Been thanked: 1160 times
Thanks and it's good to have you back
For EPIM 7.0
Thanks for working hard at the new EPIM 7.0. Attached the language file ,please enjoy the latest version.
- Chinese_Simpl.lng
- A tiny mistake has been fixed,please redownload and overwrite the former one.
- (62.18 KiB) Downloaded 448 times
Updated for EPIM pro 7.1
For the latest 7.1 final release.
BTW:where is the letters in Letter bar?
↓↓ Enviroment:
OS: win 10 64 bit
EPIM 7.1 with default new database.
↓↓ Enviroment:
OS: win 10 64 bit
- Chinese_Simpl.lng
- (63.28 KiB) Downloaded 436 times
Thanks! Letters should be there, please try to turn the letter bar off and then on again. Will that help?
The letter bar works well under annother win7 PC.admin wrote:Thanks! Letters should be there, please try to turn the letter bar off and then on again. Will that help?
I'll try it on my own pc later.
Unfortunately it doesn't work。But,when I put the cursor on the left body line of letter bar and click down ,the letters come back.admin wrote:Thanks! Letters should be there, please try to turn the letter bar off and then on again. Will that help?
Anyway,thanks for your quick response!
Could you please mention your Windows version and also your DPI settings? I see you use enlarged fonts, will check if that can cause any issues with the letter bar.
Sorry for my late.I suffered some login problems because I input wrong passwords for many times.admin wrote:Could you please mention your Windows version and also your DPI settings? I see you use enlarged fonts, will check if that can cause any issues with the letter bar.
My OS is windows 10 enterprise X64,DPI is 100%
BTW:attacked the latest language file for EPIM 7.11.
- Chinese_Simpl.lng
- For EPIM 7.11
- (63.41 KiB) Downloaded 430 times
Thanks for the update! As for the letter bar problem - please unpack the portable 7.11 version into a different folder on your USB drive. Will it help?
