Mail preview problem still not solved completely?
- Has thanked: 4 times
- Been thanked: 7 times
Re: Mail preview problem still not solved completely?
Just installed the above update, no better for me, took about 15 seconds for the preview to appear on my Gmail account
A bit strange, for several weeks the problem seemed to have been cured but it returned several days ago, possibly after the last normal update
Paul
http://www.ipgphotography.com
EssentialPim-Pro, Windows10 64bit
- Been thanked: 1134 times
That sounds like it might be related to how your email is syncing. If you've set it to only download headers first, then downloading the full message depends on your email provider and your internet connection. To check the sync settings for a folder, just click the Manage Folders button on the toolbar.
Thanks, you are correct - it now works much better.
I hadn't noticed this option before
Paul
Installed.admin wrote: Fri Feb 14, 2025 10:14 am We've made several adjustments and updates to address mail preview issues. If you're still having trouble, please download and install Build 1032 from https://www.essentialpim.com/download/t ... ull121.exe and see if the situation has improved. Thanks!
I will give it a few days and we shall see....
