ePIM Pro 12.1.2 crashes since last update
Re: ePIM Pro 12.1.2 crashes since last update
I follow the same routine as Steve when handling email and it works well so far.
Charles
Charles
- Been thanked: 1135 times
Got it, thank you both for sharing that info.
View->Preview Pane.
Email module does not work even if you turn off preview, according to the attached video!
The file was too large to attach so here is the link to view and download online.
https://1drv.ms/v/c/55d74e54a8ad692e/ET ... g?e=pdjbW2
Log filer inkl
Error_2025_03_06_18_13_31.log
- (20.18 KiB) Downloaded 9 times
Error_2025_03_06_18_13_32.log
- (20.29 KiB) Downloaded 8 times
iPhoneSync_2025_03_05_14_55_47.log
- (214 Bytes) Downloaded 8 times
iPhoneSync_2025_03_06_18_29_48.log
- (214 Bytes) Downloaded 3 times
Mail_2025_03_05_14_55_46.log
- (479.96 KiB) Downloaded 10 times
Mail_2025_03_06_18_29_48.log
- (5.08 KiB) Downloaded 5 times
MailWizard_2025_03_06_15_23_14.log
- (201 Bytes) Downloaded 6 times
SpamFilter_2025_03_05_14_55_49.log
- (8.3 KiB) Downloaded 5 times
SpamFilter_2025_03_06_18_52_06.log
- (321 Bytes) Downloaded 10 times
Thanks, we'll look into this.
I have occasionally had problems with the e-mail preview, but never a complete failure.
I copied another “webview2loader.dll”, which was on my computer and is about 40 kb larger, into the EPIM program directory and since then the preview works properly.
Since webview2 is a system component, this may also be the cause of the error. Possibly check the system with “sfc /scannow” or DISM commands. Otherwise, use the Windows 11 (24H2) restore option in the advanced options in Windows Updates (Windows Update / Advanced options / More options / Restore / Fix problems with Windows Update). The “Fix problems with Windows Update” function reinstalls the current version of Windows while retaining apps, files and settings.
ALWAYS MAKE A SYSTEM BACKUP BEFOREHAND! ! !
Good luck M&M
Translated with DeepL.com (free version)
Good luck M&M
Last week I completely reinstalled my computer and Windows so there can't be anything wrong with them.
You can post the file here so we can test it.
Hello Catamaran,
as this is a DLL from Microsoft, I cannot make it available due to copyright.
As a rule, the “webview2loader.dll” is available several times on a Windows system, otherwise the dll is also available on the Internet.
Good luck M&M
Good luck M&M
- Has thanked: 32 times
- Been thanked: 21 times
I started this thread. Just a note, Zero crashes since Feb 24. Either your updates, or stopping preview mode, or both have resolved the issue.
