Last Repeat Appt not showing in Google
markfish
Post by markfish »
I have had this happen several times and think I now know what is happening, although not sure how to fix it.
Say I create an appointment to occur every Monday at 7:00PM for 2 hours, from August 1 through Aug 29. When I sync to Google, the last appointment on August 29 does not show up. I have had the same thing occur when creating a repeating appointment for a week, say from Monday through Friday. The Friday appointment will not show in the Google calendar, but is just fine in EPIM. In the case of the repeating Monday appointment, if I change the end date in EPIM to August 30, then sync to Google, my August 29 appointment now shows in the Google calendar.
I thought this was a workaround that I could use, until I realized that if I did this with the repeating Daily appointment, I now end up with an appointment in EPIM for Saturday that doesn't really exist.
I suspect that Google sees the ending date differently than EPIM and this is where the problem lies. But since I'm not a programmer, I really don't know how to fix this. I'm hoping you can take a look at this and say "Oh Yeah, I know what to do".
Re: Last Repeat Appt not showing in Google
Thank you for such a detailed description!
Yes, looks like there is a problem, indeed. Will see how it can be fixed.
