To-Do search
Re: To-Do search
Do you mean quick search in To Do module? In my copy of EPIM it works fine.
Re: To-Do search
On Android device, I pressed Menu/More/Search.Max wrote:Do you mean quick search in To Do module? In my copy of EPIM it works fine.
No, it does not work.
From the list of Tasks, I can see in the Notes line below the searched word, but Search says Task not found.
Using HTC Desire Z with EPIM 1.3.6 running under Android 2.3.3
John
- Been thanked: 1134 times
Re: To-Do search
Confirm, will fix in the next version. BTW the latest Android version is 1.4.
