Syncing questions
EricG
Syncing questions
Post by EricG »
Hi, I'm trying out EPIM and had couple of questions about syncing.
I've seen in some other threads here that people were asking about a way to sync without using the cloud, ala wifi, etc.
I'm just the opposite, and I want to sync through the cloud. Is there a way to do this?
I'm attempting to sync through the use of Google Docs (Google Drive, now) and can get the PC version to sync, but am not sure how to set up the Android side.
When I try to sync on Android, it asks for a server IP address and port number.
Any way to bypass that and sync direct to cloud?
Has thanked: 1616 times
Been thanked: 1135 times
Re: Syncing questions
If you want to sync through cloud you can do that via Google services. Just note that Notes and Passwords modules will not be synchronized in this case.
EricG
Post by EricG »
Ok thanks, I'll check back in the future.
Notes are the main things I'm interested in.
