previous versions of Android app
is there any possibility to still get the older versions of the EPIM apk file?
I have an Android 2.1 device, and the current version is not compatible anymore, but I know that an older version was compatible...
thanks,
Samuel
thanks,
Samuel
- Been thanked: 1135 times
Re: previous versions of Android app
As far as I remember all the previous EPIM Android versions required Android 2.2 or newer. I can get you one of the older versions but:
1. Not sure it'll work with Android 2.1
2. You will not be able to synchronize (at least without issues) with the latest version of Windows EPIM as there's been some big changes in synchronization
